Watch 5 Pro vs Watch 4 Classic battery comparison
(Topic created on: 26-08-2022 09:07 AM)
Neofit26
Hi,
I bought the Watch 4 Classic at realease, and pre-ordered the Watch 5 Pro that I received a few days ago. I was happy with the Watch 4, even though recharging every day was a bit of a drag. I was interested in the Watch 5 Pro due to its larger battery. So I decided to test it,whether it really lasted longer with my usual settings and usage, and whether it was worth losing the big ring.
Test conditions: watch4 and watch5 both recharged to 100%, then both worn at the same time, and if I noticed that one lit up, I'd light up the other. Settings where copied from the 4 to the 5.
Here is a table, with the percentages per watch, the the percentage lost per hour for each watch. Comments say when I turned Eco mode on or off, and I didn't wear them during the first night.
Date time Watch 5, % Watch 4, % W5 %/h W4 %/h Comment
24/08/2022 12:45 100 100     Eco, worn
24/08/2022 22:00 94 81 0.65 2.05 Eco, not worn
25/08/2022 08:45 88 64 0.56 1.58 Eco, worn
25/08/2022 12:45 79 45 2.25 4.75  -Eco, worn
25/08/2022 22:00 55 7 2.59 4.11  -Eco, worn
26/08/2022 08:50 33 - 2.03   W5 wins
Roughly, the 4 is using about twice the % of energy as the 5, with my usual settings and usage. And, I never checked the actual numbers before, but eco mode uses bout 1/3 of the energy used in normal mode. I wish we could have eco mode but with the watch turning on with the wrist gesture though.
IMHO the extra battery is worth it.
3 REPLIES 3
Neofit26
Also it estimated 22h hours left in eco mode and 18h30 without eco when I was at 33%
IndiW
Hotshot
Well done 👏 good work
Minhajj
Hmm Nice
