25-10-2022 01:21 PM in
WearablesI have a problem with making and receiving calls on my Watch 5 LTE but sending and receiving texts works fine.
When my phone is next to my watch - i receive the phone calls fine but when i leave my phone at home, i can only send and receive texts on my watch. Phone is on and connected to wi-fi, has mobile signal.
I am with o2 and have purchased e-Sim with data plan from them (O2 has only one plan that gives you 1GB for £6/month).
I checked and i have setting on the phone to allow phone calls from other devices enabled.
On my watch --> Connections--> Mobile plans --> it only shows one SIM card . should it show two?
On my watch mobile network is set to auto
Power saving mode - disabled . not sure if it make any difference though?
Can anyone suggest what am i missing here?
thanks!
25-10-2022 03:57 PM in
Wearables@Confused100: Your Galaxy Watch 5 has an eSIM, so this is the only SIM that will show up in the Mobile Plans settings menu. Have you tried reaching out to O2 to check if your eSIM supports calls and texts, as the inability to make calls may be a current restriction of your plan.
25-10-2022 07:21 PM in
Wearables25-10-2022 07:26 PM in
Wearables25-10-2022 08:19 PM in
Wearables25-10-2022 08:24 PM in
Wearables25-10-2022 08:38 PM in
Wearables
