Treadmill - is it not considers as "running"
(Topic created on: 18-09-2022 09:54 AM)
IndiW
Hotshot
Hi guys
In Samsung Health, running on Treadmill, is it not considers as running?
Ta
4 REPLIES 4
Reylob
Samsung Members Star ★★
I guess that it is consider as running, but it has a separate entry to create a difference from running on treadmill and outdoors.
Why are you asking? What is the difference between the two modes? Does the step count increase?
I do run but only outdoors, so my comment is opinion only because I have not used a treadmill for over 7 years or so.
Technology enthusiast, but not related to any technological company.
IndiW
Hotshot
Thanks friend
On this side of the phone.. I use treadmill only 😂😂..
However just to calibrate the watch I did 2km outdoor running and received a "trophy" from Samsung app, for longest distance
Then I did 10km on Treadmill, I received, longest time duration, most calories burned trophies but not for the longest distance.. So I feeling sad 😔.. 😢😢👋
GusB
Yes. But it won't track certain data points due to no GPS used
**Photography IG: @slappa_da_tubs | Travel Vlogs YT: GusBan Travels **
Reylob
That is a good point.
