Samsung Gear S3 Not Connecting with Xiaomi Mi A3
(Topic created on: 18-10-2019 12:19 AM)
SulaimanAnik
Today I bought Mi A3, everything is fine but it's not connecting with Watch, last pairing option it's disconnected. Any solution.......
I updated all plugins and Wearable apps also given all permission to apps but please help.....
9 REPLIES 9
joel25
The same thing is happening to me with my Xiaomi Mi A3 gave me an error before finishing the configuration and I had the clock working perfectly with another phone
tonelin1124634
The same thing is happening to me with my Xiaomi Mi A3 gave me an error before finishing the configuration and I had the clock working perfectly with another phone. please help, give us a solution
alperaydın
 thanks very much. You solution fix my problem. I tried everthing bacground working, battery optimizations etc etc. But your solution fix my problem. really thanks to you.
Alena1984
Thanks! I was desperate but your advice helped!
DinkyTesla
Thanks, turning off the WiFi fixed my problem too!
MAZTERGEDAY
Thank you very much, it worked perfectly with my Samsung Gear S2 !
MkKrkPoland
Thank you -I finally managed to connect using your procedure. I may need to post another thread for another question that I have tho...
GalaxyLTEWatchOwner
HI Sulaiman,
I am stuck with the same situation and Mi A3 not getting not connecting with Watch,  it gets disconnected at the last step.
I updated all plugins and Wearable apps also given all permission to apps. I saw that you experienced the same issue and found some solution also. I tried opening your URL, but its not working now. Can you please suggest how to fix it plz?
