16-02-2021 02:16 AM
Can someone please explain why my galaxy watch is needing to be charged so frequently? Fully charged overnight but after only 6hrs only 16% charged! Only had it 2 months and not using apps like Bixby, music etc.
Solved! Go to Solution.
16-02-2021 05:20 AM
Have you downloaded apps / widgets onto the phone that is using battery @Hound Dog
Some are more resource hogs than others.
An extreme option would be to reset the watch.
I wish you all the best with this.
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
24-02-2021 01:58 AM
Thank you so very much for your help. I ended up having to totally erase everything from the watch and set it up as a connection to new phone. Charge lasting 2 days now. Thanks again. Only had it 3 months so contacted seller - didn’t even get a reply!!
16-02-2021 05:20 AM
24-02-2021 01:58 AM
24-02-2021 06:02 AM
You're very welcome.
Fingers crossed all goes OK from this stage for you @Hound Dog
