Go to solution Solved
Left ear buds plus is not connecting.
(Topic created on: 30-08-2020 08:05 PM)
ALahson
Hi
I was using both ear buds this morning. Battery was completely drained so I put them back in the case to charge.  Now I can see that they are both charging but only the right ear bud connects. The left one doesn't connect.
I have attached images showing the wearbles app. A picture of both ear buds charging and a picture of the left ear bud charging.
ALahson
Went to the Samsung store and they advised they will either fix them or replace them with new ones. Got to say one of the best customer service I received.
No receipt or proof of purchase required. They said the only time they won't fix or replace is if its water damaged or if they are dropped.
19 REPLIES 19
Amunnie
Navigator
Have you checked the contacts? in case there is some dirt preventing it from charging?
Shelley123
Voyager
I was going to suggest the same as amunnie as I had the same problem after a little wipe over mine started charging up again.
ALahson
Hi
I have cleaned them with cotton and replaced the tips and the plastic that goes around the buds. I unpaired them and paired them again. Still nothing in the left ear bud.
panchels
I have exactly the same problem
Amunnie
Navigator
Hi again ! Sorry to hear that didn't help. Have you allowed both to charge fully in the case then reconnecting ? Also try this, (sorry if you already have) completely disconnected them from your phone, unpair them. Then switch them off. Switch your phones Bluetooth off and then turn the phone off. Turn the phone on, turn the Bluetooth on and then turn on the earbuds. See if this works
Amunnie
Navigator
Hmm, I notice one earbud is 100%, perhaps that's preventing the other from charging as the case might assume its full. try draining the battery of the one ear bud and charging again. if that doesn't work, you might have to contact Samsung under warranty and get a potential replacement
ALahson
Thanks for your suggestions, I have tried that and it didn't work. I'll try  draining the right ear bud and see if they charge after that. I tried taking it to Samsung as its under warrenty but because of covid 19 I had to make an appointment which is in 10 days.
ALahson
Also as you can see the green light is lit and it is normally green when both are fully charged.
ALahson
I have researched and this seems to happen to a lot of people. Does anyone know what's causing it and are Samsung doing anything about it?
From running a few tests I can see that it's draining battery off the case but the airbod is not charging. Some thing seems to be wrong with the battery.
