How does watch 4 not have a left handed mode ?
(Topic created on: 22-11-2021 12:20 AM)
Iamralphs
Especially since you have two simple buttons on one side ?
Just let me flip watch.   And have an option to rotate screen and flip buttons then it's done.   Easy!
Apple has this feature.  I just bought the watch 4. And honestly shocked it doesn't.  Especially since a lot of the sensors require you to hold your hands to the watch in a way that's impossible in the right wrist !!
5 REPLIES 5
Paulf1
Voyager
Send a diagnostic and report it to samsungs tech team, won't hurt and they could put it into an update in the future I doubt your the only person who has noticed this..worth a try.
Iamralphs
Apparently - this issue has been going around for over 3 years - - so I doubt my diagnostic send will do anything.
Paulf1
Voyager
Don't understand the problem anyway I where the watch on my right hand without a problem and it asks if I'm wearing on left or right..
Galaxy watch classic+galaxy watch 4.
Iamralphs
The problem is - the buttons are on the wrong side.. so A.. its' a bit uncomfortable - but more importantly B --- all the metrics to measure your body are geared to you touching those two buttons and raising your arms and not touching anything else --- the way  they want you to do it -- is simply not possible on the right arm.        So bypassing the fact that it's just a tad annoying...  if you want to use any of the health analytics you need to put it on your left arm.    Makes sense?
Paulf1
Voyager
My health still takes readings on my right arm but maybe there's a problem with the watch can't you return it for repair or exchange ..hope you get it sorted..
