GW4 - saving some battery usage at night
(Topic created on: 05-05-2022 09:39 AM)
papashaun
Troubleshooter
I now turn off the " touch to wake " option on my watch before going to bed at night and find the overnight battery usage significantly reduced.
I sleep with bare arms and tend to sleep with my arms huddled up - realised that my watch must constantly touch my other arm during the night so the watch display is being turned on quite a lot when I'm sleeping and obviously increasing battery usage !
1 REPLY 1
Neo001
Legend
Try the bedtime mode. No need to turn on and off the touch to wake feature in the setting manually everyday. You can set a fixed time for the bedtime mode to get activated automatically, if you sleep around the same time every day. You can of course turn it on and off manually via the quick panel.
Hope this helps.
