Battery draining.
(Topic created on: a month ago)
Weaver79
I have the watch 6 series since Sunday the battery is only lasting a few hours. I've only had the watch since August 23 there are not updates needed. Any suggestions. It's on saving mode but still draining rapidly. Thanks
1 REPLY 1
JAMES4578
Samsung Members Star ★★
@Weaver79  Ensure apps up to date and not too much running in Background. Do  you have Always on Display turned on,  idea to have connections running only when needed. other optimisation tips here https://www.samsung.com/sg/support/mobile-devices/tips-for-increasing-the-battery-runtime-of-your-sa...
However it look like you may need to clear the cache partition:
You should have the battery fully charged before starting this process on your smartwatch.
1. The Samsung Galaxy Watch must be turned on.
2. Now press and hold the "HOME" and "BACK" buttons simultaneously until you see the Samsung logo with "Rebooting".
3. Now release both buttons immediately and now press the home button (top right) quickly one after the other.
4. You are now in the boot menu of the Samsung Galaxy Watch. In this menu you can scroll with the "HOME" button by pressing it repeatedly.
5. Now navigate to the menu item "RECOVERY" and then press and hold the "HOME" button. This will reboot the Samsung Galaxy Watch into Android recovery mode.
6.You are now in recovery mode, which is similar to that of Samsung Galaxy smartphones.
7. Now press the "BACK" button (lower button on the right) until you have selected the menu item "WIPE CACHE PARTITION". To select it, press the "HOME" button once.
8. Now select "YES" by scrolling down and then select the entry with the home button.
9. The Wipe Cache partiton will now be executed on your Samsung Galaxy Watch. This takes a few seconds. Afterwards, the recovery menu is displayed again. Now select "Reboot Now" to restart the Samsung Galaxy Watch.
otherwise could Reset the watch and pair again.   https://www.androidpolice.com/samsung-galaxy-watch-reset-how-to/
