Gear3 Frontier stopped working after Samsung's update
(Topic created on: 01-02-2021 10:39 PM)
Krys11
Hello,
has anyone experienced an update from Samsung to Gear3 frontier that has completely killed the watch?
It doesn't charge anymore, nor starts up.
I wonder if anyone had it and found a fix?
I will appreciate any suggestion.
Krys
7 REPLIES 7
papashaun
Troubleshooter
Hi - I haven't had an update to my Frontier for quite a while - only for the Wearable app on the phone
Have you tried re starting it - press and hold the bottom button for a few seconds and see if it re starts ?
Also does it show in the Wearable app on your phone ? If so could try the reset option in there
Murphmrm
Pathfinder
try holding both buttons for several seconds for a hard reset
Krys11
thank you, both. i had to install an outstanding update on the app and that has enabled the reset. unbelievable!
papashaun
Troubleshooter
Glad you got it sorted !
Krys11
it worked nearly a day and died again. not sure if the software in the watch is failing but i cant turn it on.
Keith-Longpre
I'm facing the exact same issue, I will also note when I took it off the charger the first time it was extremely hot to touch and burned my finger tips.
Krys11
Unfortunately I didn't manage to resuscitate mine. It seems that updates are meant to phase out older models these days.
