Galaxy Gear SM v700 wont turn on
(Topic created on: 07-02-2021 10:40 AM)
clive5
Please!! I need help, I bought a very good condition Galaxy gear off facebook and it was working fine, I installed a couple of apps and I was playing it until it drained to 15% and then immediately turned off. Then, when I charge it, it turn on but say i charge to 50%, then I turn it on, it will just shut off and go back to 0%. I don't think this is a battery problem as when I press on the bottom left hand corner, it turns on fine and doesn't turn off, but as soon as i let go, it turns off and immediately drains every single bit of the battery. I don't understand why this is, I really need help! Please!!
3 REPLIES 3
Pugs1957
SuperStar
This device needs to be physically examined to give a diagnosis. It's really not possible via a forum.
clive5
So how can I do this? Do you have discord so I can screen share and you can tell me what to do, thank you!
Pugs1957
SuperStar
I would help if I could but I'm not a technician sorry.
