Galaxy buds pro issues
(Topic created on: 16-03-2022 08:37 AM)
BasicZero
Pioneer
Over the past few days of having my buds pros which I do really like. The fit is just awful the small eartips don't provide a great seal and they still feel like their going to fall out. The medium tips are big that they don't fit into place and still feel like there going to fall out. I've had an issue like this before with the lives. I'm now considering reverting back to my previous buds (buds+) like I did last time. Hopefully going to try the buds2.
2 REPLIES 2
smiley
Samsung Members Star ★
if it helps, I bought a set of these in the medium set.  It gave some options within my typical ear size.  They are quite expensive, but feel good quality and I have used for a while with a good isolation and not much irritation.   Some of the cheap replacements have both good and bad reviews... these were quite well recommended.
Of course with ear buds, if you starve your ears of air for long periods, it will generally cause some irritation.  If it is a couple hours use... I like the buds.  Anymore time and I default to over ear headphones to reduce the risk of irritation.
AZLA SednaEarfit Crystal for Galaxy Buds Pro 3 Pairs (M SET): Amazon.co.uk: Electronics & Photo
Kind Regards
Smiley
User: Smiley
If my reply has been useful in resolving your issues, then please like and 'mark as solution'.
My life is full of positives and negatives. I’m an electrical engineer.
BasicZero
Pioneer
Thank you I'll have a look
