Finishing my exercise while running
(Topic created on: 16-05-2024 07:35 PM)
izzy33
So the last 2 runs now my galaxy watch 6 repeatedly comes up with it looks like you have finished your work out mid work out I'm constaly having to resume work out while runing which is very offlutting when ur in the zone I've turned auto pause off and it's still happening this needs to get fixed as I'm at my wits end.
6 REPLIES 6
smg1
Troubleshooter
I recommend you submit an error report through this members app. Thar way you are asking Samsung experts for help.
I've submitted one for a different issue. No result yet, but you are taken very seriously, and you can keep going back to them for updates and add any further issues you find.
CR811
Did you manage to sort this out? Last 2 runs I've been on its done the same thing. It's happened again just now. It's annoying like you say especially when you're into it.
izzy33
No I've chatted to the tech team the suggested sending watch off which other people on here have done with no success as its a system error not a watch error( my partners watch does the same ) there's nothing to be done I've raised a complaint I've logged a fault I'm very disappointed in samsung tbh they need to do an update that fixes this bug but we are all being ignored.
emertinsp85
This is just a wild guess, but I think this is a system bug/issue somewhere. I don't particularly use Health, but use Adidas Runtastic. It started happening easily 2-3 months ago where the app would simply stop the run and mark it as completed without any message or warning. Thought it was the app, so switched to Nike Run. Same thing. Strava? Yes, also auto-stops the run. I then began reading up and plenty of people are reporting the watches stopping to track. Used Health to give it a try, and same "Looks like you have finished" message.
It's been months. Still not fixed. Oh but Watch7 is expected to be announced soon. I get the feeling we got burned with the 6.
izzy33
I will not be buying the 7 of the issue conti yes, with the 6 tbf as its ridiculous 🙄 so fingers crossed it gets sorted x
Lain15
Both my 5pro and 6 do this, Although I never use my 6 as the battery doesn't last long enough, Definitely won't be buying the 7. I'm currently looking at Garmin watches.
