Go to solution Solved
Excessive Battery Drain - Gear S3 Frontier
(Topic created on: 17-01-2018 08:32 PM)
EJ7
When I first got my Gear it burned through batteries so quickly. Then there was an (Tizen?) update released last Fall I think it was which made it a lot better - I could make it through a full day without charging. Then there was an update just the other day, and now I can barely make it through half a day. Something is sucking the juice of out of my battery. Please hotfix it Samsung ASAP! It's not a wearable anymore, it's more like a chargeable.
Tizen 3.0.0.1
2 Solutions
BandOfBrothers
Samsung Members Star ★★
Hi @EJ7
My s3 frontier appears to be ok.
What update/ firmware version is it on ?
Do any stats in the watch give any idea whats using most battery.
If your concerned and a reset does not help then a Samsung Experience Store or Samsung Service Centre location can run a diagnostic on the device.
Daily Driver > Samsung Galaxy s²⁴ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
CaptainKaptein
Hi there. Had a similar problem, it was a third party watch face. Had 5 hour battery now 14 hours or more after deleting
 it.
6 REPLIES 6
BandOfBrothers
Hi @EJ7
CaptainKaptein
 it.
BandOfBrothers
Where did you get the watch face from @CaptainKaptein
CaptainKaptein
WatchMaker
BandOfBrothers
Ah right.
I acquire mine from the Gear App.
gary5859
Tizen 3.0.0.1
Hi. My Samsung Galaxy Frontier Gear S3 also have this problem. After update to Tizen Version 3.0.0.2. My battery drain very fast. Only can use arround 7 hours only. Before update i can use most arround 2-3 days just charge. Can you please solve the software problem?
