04-11-2024 11:10 AM
04-11-2024 11:27 AM - last edited 04-11-2024 06:23 PM
No judging here just a bunch a questions
1-did you drop it as such its internals are damaged?
2-or, did you expose it to water or liquids that eventually seeped inside and caused a damage?
3-or, did you expose it to extreme temperatures hot or cold?
4-or did you use an incompatible charger with it that fried its circuits?
If none of the above took place and you were using it as intended by the guide lines, then probably it's a damaged unit and you can replace it if its still under warranty
04-11-2024 11:35 AM
04-11-2024 11:37 AM
05-11-2024 04:07 AM - last edited 05-11-2024 04:08 AM
05-11-2024 10:00 AM
18-11-2024 12:55 PM
14-02-2025 12:08 PM
I have exactly the same issue with mine.
