Battery Drain
(Topic created on: 10-12-2024 07:41 PM)
jezzer_72
Since the update to One UI 6 , the battery on my watch 6 is decreasing super fast. It's used 20% in 9hrs. Stress monitoring continuous, heart rate monitoring every 10mins.
It lost 5% in am hour this morning. Any ideas what's causing it? Shall I downgrade and try to upgrade again? Help!
8 REPLIES 8
lminvti
Samsung Members Star ★
Hi there
You could try wipe cache partition:
https://eu.community.samsung.com/t5/wearables/ridiculous-battery-issues/td-p/8276249?src=ShareByUser...
Steps:
Hold both the side buttons simultaneously until the watch turns off.After the watch turns off, start pressing the top button repeatedly (no need to hold the bottom button) until you see the Select Reboot Mode menu.Using the top button, move the selection to "Recovery" and hold the top button to select it.Wait for the Recovery menu to load. Now using the bottom button, move the selection to "Wipe cache partition" and click the top button to select it.Next, select the "Yes" option using the bottom button and click the top button to confirm.You will see the wipe cached and the "Reboot system now" option selected. Press the top button to confirm it and the watch will reboot and turn on.
Sharpieee
I've purchased a Samsung HW-Q600C/XU soundbar but I can't register it through SmartThings because the QR code won't scan and the model isn't in the list for manual entry. Any ideas?
jezzer_72
I've wiped the cache both on my phone and watch. Improvements on my phone but nothing on the watch
lminvti
For how long you had update for your watch? As it sometimes battery needs to adjust after update.
jezzer_72
Think it was updated on Friday
lminvti
Yes, then give some time, like a week or so, as the battery cycle needs to adjust after update and then see how it goes as mine one had same thing but after week it became normal.
jezzer_72
Looks like you were correct. It's gotten a hell of a lot better after a few days
lminvti
Glad it was helpful 😊 happens after updated sometimes battery just needs adjust. Glad was able to help 👌
