Battery Drain on Samsung Gear S2 Classic
(Topic created on: 22-05-2017 08:37 AM)
Jonnycab
Hi there
my s8s battery has drained from 100% down to 75% I an hour and a half after unplugging from the charger, does anyone have any advise on what this could be?
I have removed any apps that are not being used
2 REPLIES 2
BandOfBrothers
Samsung Members Star ★★
Hi
Can you check any battery stats are as they should give you an idea.
The Bluetooth used to pair your phone and watch shouldn't use much battery at all. Actually should save phone battery as a person typically checks their watch when a notification hits.
I've heard factory resetting the watch can help and check your on the latest software.
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
Lexo
Hi
I'm having this same problem. My Gear S2 battery starts to drain quickly as soon as I connect to Bluetooth. I have done factory reset several times but it hasn't made any difference. I reset my Galaxy S7, the problem stopped for a day but started again after this. What should I do? Can anyone help?
Lexo
