Alti-Barometer Does Not Work!
(Topic created on: 25-06-2019 02:53 PM)
Faruk_
Hello,
After onu ui update my alti-barometer stopped working. Tried factory reset did not help, i go to test mode and barometer sensor says "FAIL" but SensorHub says "PASS".  This device bought one month ago so i want to know is this software or hardware related problem?
In addition to all of this floor counting not working as well.
Thank you.
Tags (2)
6 REPLIES 6
AndrewL
@Faruk_: If you access Alti-Barometer via the Apps screen and scroll to Settings > Change > Auto Refresh, does the calibration occur as expected? If not then based on the troubleshooting steps you have already attempted I recommend visiting a Support Centre to get the device inspected by an engineer. To find your nearest one please check the link below, select 'Mobile Device > Phones, Tablets and Wearables and enter your post code.
http://www.samsung.com/uk/support/servicelocation/
Faruk_
Already did "Auto Refresh" option but still same. I dont know whether i should go to RMA or not but i think this issue might be software problem.
alligator82
Hi, I'm having the same issue for the past several weeks. Have you managed to fix it? Mine is out of warranty already.
alligator82
I think I found a solution for this issue and I wanted to share it with all of you. It is really odd but it actually works at least for now.
I tried to uninstall the app Alti-Barometer several times but this didn't help (never tested to factory reset the watch but I believe this won't be helping as well).  I went into the Test mode of the Galaxy Watch using the dialer and entering the code *#0*#. Then select Sensor and check Barometer and Altitude indications. For me all these have been stuck on 0 and if you click on the button Self you can see a big red FAIL. I uninstalled the app Alti-Barometer once again and turned off the watch for at least 12 hours. Then I enabled the watch and went into the same Test mode and voila - all sensors have been working correctly without a problem and you can see a big blue PASS. Then I reinstalled the app once again and everything is working now.
Let me say that in my situation this was the only app which was not working. TBH, I never used it so often but something bugs me and I was searching for a solution last several weeks. I heard for some cases where a lot Samsung Health sensors are not working but I'm not sure if this solution will help for their scenario.
Good luck everyone!
Natral
Is that solution still working today 17/06/21?  It didn't remain working for my Galaxy Watch.
I've found that simply switching the watch off and leaving it off for about an hour (or all night), always fixes Alti-Barometer completely. But, and it's a big BUT, the fix doesn't last for very long and gradually, over an hour or two, the 'Last 6 hours' charts will disappear and eventually so will the altitude and pressure readings. It seems as if the watch is each time gradually overloading its own 'brain' with Alti-Barometer app data? Samsung should sort this easily & quickly, especially as it's all, just fine for a while, after a prolonged shut-down of the watch.
I'm wonder if uninstalling some non-essential apps might help?
alligator82
No, it worked just for a short period of time. Then I had to do it again several times but it is not a permanent solution, unfortunatelly.
