16-05-2023 08:12 PM - last edited 16-05-2023 08:13 PM
I've had the wonderful UE65NU7400 since 2018 and have always had the correct "XBOX One" logo when connected to my old Xbox.
Having recently switched to an Xbox Series X, I now just get the generic blue tile with "XBOX" in white text.
Is there any way to get the proper icon back?
Many thanks.
13-09-2023 09:53 PM
I have the same problem on my Samsung AU7105, it used to work but now the generic blue icon appears and no matter how many times I have disconnected and connected the console so that it can detect it again, the green Xbox icon does not appear
13-09-2023 10:07 PM
I spent about two hours on the phone to support just for them to say they don't know why. I also asked both Samsung and Xbox on Twitter, neither of who had any idea. Tried Samsung support online chat, and they said they had no plan to add the Series X icon, but I'm not convinced they even knew what I was walking about because other people are saying they've already got it.
13-09-2023 10:12 PM
The correct green Xbox icon appears on my TV until yesterday, I changed the room TV and now it does not appear when what is connected is the same in the same place
15-11-2023 01:00 PM
I had the same problem for Xbox One. Removing the Xbox from the universal remote and reconnecting the console to HDMI helped. Maybe it will work for Series X too
27-12-2023 07:05 PM
The icon now properly appears when I go to the universal remote setup and during the setup it let's you choose the brand for the input type.
10-01-2024 08:26 PM
what's the universal remote and how do I access it?
10-01-2024 08:26 PM
What's the universal remote?
10-01-2024 09:18 PM
The universal remote is the smart remote which comes with your TV. You can go to connections and connect a device using it.
Although Millennium said it worked for them, it hasn't worked for me - still no Xbox SX logo.
08-07-2024 06:40 PM - last edited 08-07-2024 06:40 PM
I was trying to fix the same (Xbox icon dissapeard, because I tried to connect Xbox through soundbar because of Atmos big delay when using ARC), fix is quite easy in the end, unplug and plug xbox in while TV is on, TV will recognize new device (this step create icon in the dock) and voila. Icon is back, at least for me. But there is no other way how to do it. If you connect Xbox to TV while TV is off, nothing change. Hope it helps. QE55Q77AATXXH + Series S. Kind regards, Martin
