WMN750M mini wall mount
(Topic created on: 27-02-2021 05:24 PM)
Gally67
Has anyone used the WMN750M mini wall mount on the Q80T series TV?  Samsung have told me that this is a compatible wall mount for my TV (55") but I can't get it to fit.  The clips that are supposed to be screwed to the TV do not fit into the holes for the screws/bolts.
Samsung tell me that the 2020 does not require holding rings that other TVs do but the clips will not fit.  If It could attach a picture I would and you would see plain and simple.  But right now I've spent £70 under the advice of Samsung support for something that's no good.
0 REPLIES 0
