S95D - remove stand
(Topic created on: 14-12-2024 05:55 PM)
lami17
Hi all, today I was trying to remove the TV stand that the Oled S95D 65" comes with (we want to mount it on the wall instead). We tried to 'unhook' the part that is shown in the his video at 1:02: https://youtu.be/a9Wsmw3UM1c?si=FhwmGy_0fHStEkXg.
We tried this for a good half hour to no avail. Any tips on how to best to do this? We tried pulling back the plastic hook here, but the thing wouldn't budge!
4 REPLIES 4
Kb34
Having same issue, did u figure it out ?
lami17
You will need something sturdy to put in the gap the stand (the very heavy bit) and the part that is screwed to the TV, th n you can lever the stand off.
I bought a angled screw driver at first and whilst trying to unscrew the screws that are so difficult to get to the stand accidentally snapped off with the levering force just described.
n3biot
There are two ́pin’ on one part of the stand. First you have to make this two pins gettin out of their hole by movong the stand. While keeping the 2 pins  out of their hole you can try to move the plastic thing to remive the meral piece.
