Wireless LAN adaptor
(Topic created on: 02-10-2020 10:47 AM)
Levi88
Which wireless LAN adaptors are compatible with Samsung smart TVs to connect them to wifi?
6 REPLIES 6
Harveyx1
Helping Hand
if its a smart tv it can already connect wirelessly
TRY2HELP
Helping Hand
dont your smart tv have build in wifi all smart tv have it, unless it not working, then you can buy wifi extend, plug one in your tv ethernet and the other in the modem router, and buy any make or model like belkin that a popular name.
Levi88
My model hasn't got built in wireless, when I click on network settings it says "no wireless LAN adaptor connected" so I was wondering which adaptor would be compatible, to link adaptor etc?
Levi88
Tp*
TRY2HELP
Helping Hand
do you have a ethernet port at the back for internet collection, if you have you can use that, and if you tv far from your modem then buy a wifi adapter, it give you 2 small plug, 1 plug in your tv and the other to the wifi modem at home, it can be any name or model, as I said before belkin is a popular name
Levi88
Yes it has ethernet port but abit far from modem so will try WiFi adaptor, thanks
