WiFI with Hidden SSID
(Topic created on: 14-02-2022 02:14 AM)
MKPD30
I have a Samsung 7 Series 49 inch smart TV (#UA49RU7100RXSG). I have a WiFi connection where the SSID is hidden due to security issues. I have to enter the SSID and password every time I need to connect my TV with my WiFi connection. Has anyone encountered this issue and solved? Please assist me to overcome this situation. Please note that I usually disconnect the power supply as well to reduce any power surge risks. Thank You.
1 REPLY 1
JAMES4578
Samsung Members Star ★★
Hi @MKPD30  Can you check your Router settings in the admin page?   You should have information from ISP, but if not known I could check.    Some detail here  https://uk.pcmag.com/wireless-routers/83093/how-to-access-your-wi-fi-routers-settings in your Wireless settings you should  have an option to Broadcast the SSSID.    Hiding it does not really increase security as shown in this article https://www.alphr.com/should-broadcast-wifi-ssid/
