Wall mounting ue49k6300ak tv
(Topic created on: 03-01-2021 03:09 PM)
MWelch93
What size M8 screws are required to fit the 49 inch Samsung curved tv to a flat wall mount? I've tried M8 30mm as advised on Samsung FAQs but they are too short when using TV bracket adaptors. There is also a difference in depth, with the top two holes being several mm shallower than the bottom two.
1 REPLY 1
CarlH
Hey @MWelch93. Looks like it has to be 43-45mm according to page 7 of the manual. Hope this help!
