Go to solution Solved
Voice Control button on MU6300 no longer works
(Topic created on: 06-11-2019 08:36 PM)
CPAGAL
My MU6300 has a great remote that allows me to tell it which channel I want instead of clicking through the series of channels.  But it no longer works.  I've updated the software and re-paired the remote.
I've read thru most of the messages about this problem....but I don't see an answer.
Any ideas?  My tv is no longer under warranty.
Pam
JAMES4578
Samsung Members Star ★★
Pam
Hi @CPAGAL    Have you tried the following which can provide a solution:
Turn off TV
Unplug from power point
Hold down the return and 4 colour button till remote stops flashing
Reconnect power plug to wall socket
Turn on   the TV
Remote should then  resync to the TV and if so the voice  control will be active.
Problems are sometimes caused by server issues.
3 REPLIES 3
JAMES4578
Pam
Turn off TV
Turn on   the TV
CPAGAL
Thanks so much, James!!  Your advice did the trick!
JAMES4578
@CPAGAL   Glad to hear voice control now working  Pam!
