usb hard drive or flash on TV QLED SAMSUNG QE55Q70R
(Topic created on: 17-02-2024 10:06 PM)
mbooma
HI,
I have a samsung TV from 2019, I always used my  "128 Go" USB flash drive without any problems in both usb port, now I have "1 To" usb flash drive who is detected on pc without any problem but not detected with samsung TV ( I tried to format it (exfat fat32 and NTFS),  also to change it from MBR to GPT and MBR again without any succes, so I suppose it's energy problem and the flash drive don't have enought energy from samsung TV to run correcly (just tell me if I am wrong, I don't pretend to be an expert),I also tried both port(usb one and usb for hdd one)
now I want something with "2 To" capacity and can run on samsung TV, I see that samsung has 2 To usb hard drive but without alimentation port, so i suppose it will not work on TV ? do you have any idea to play all my files on TV ?
will Samsung SSD Externe T9 USB 3.2 2To work on HDD port ?
thank you in advance.
1 REPLY 1
Knb
If I'm not mistaken,  a old school hard drive has to be used, not flash drives.   This is what my qn800 manual suggests.
