13-05-2020 05:21 PM in
TVHi all!
Vodafone (beforehand UPC) just changed my Horizon STB for a Vodafone TV box. For this i can not setup the universal remote, the TV can't recognize it, and i can't find it with a manual search either (had no problem with the Horizon box).
Anyone had a similar issue, and maybe know what to select for the universal remote to work with Vodafone TV box?
Thanks in advance for any help.
Solved! Go to Solution.
22-06-2020 09:30 AM in
TVHello the name must be given to vodafone. After that you have to press the page down button on the screen. Until you change the channel.So I did the same with this box.Samsung mu 6102 on tv
14-05-2020 02:06 AM in
TVOn the TV box there is only Vodafone brand written, but in it's menu I was able to find out that the Vodafone TV box is a SAGEMCOM DCI362-UHD, but sadly this exact model is not found in the setup, so still no luck with the universal remote. 😞
23-06-2020 05:15 PM in
TVThanks for the hint. Works on Q7FN 4K as well!
23-06-2020 05:22 PM in
TVYup, this worked for me too. Thx for the help!
23-06-2020 06:46 PM in
TVHey there, it is rather a Vodafone box related question: do you happen to know how to hide unwanted channels? I looked for it forever but am not able to figure that out...thanks
24-06-2020 01:24 PM in
TVHi. I was looking for this feature too, but can't find it. I think it's not included in software.
25-06-2020 09:16 AM in
TVHey, thanks for checking.
In addition I discovered that the Dolby sound at dedicated channels is missing as well - at least my Sonos Playbar gets stereo only - eventhough I tried many settings on the set top box and the TV itself.
Hopefully with a software update this and the channel ordering will be fixed!
01-10-2020 04:51 PM in
TVSzia László, Nem bírom párosítania a TV távirányítóját a Vodfone TV-vel. Neked, hogy sikerült?
Köszi, Attila
20-01-2021 12:23 PM in
TVLászló sorry but i didnt understand you well! Can you explain again please. I have the same problem with the vodafone media box
