13-08-2023 04:33 PM
Hi,
I have a UE55RU7020KXXU. Apple TV was preinstalled and worked fine for a long time.
My subscription expired and I stopped watching. When I went back to it some months later the app kept crashing when it was booted.
I followed all the instructions for a fix and none worked, so I resorted to removing the app and attempting a re-install.
Now it won't install. I keep getting error code 243019. Any suggestions?
The system has been reset and is up to date.
13-08-2023 05:32 PM
@tstv Have you tried a Factory Reset,disconnecting Tv for a minute and rebooting router at the same time (even if there appears to be no issue with internet)
Some information also here https://discussions.apple TV-
14-08-2023 07:49 AM
@JAMES4578 yes, thanks. Tried all that. It's very frustrating.
21-08-2023 04:09 PM
Exactly the same issue with my Samsung TV for months now. Same error code for Prime video and Apple TV, neither will install. Tried multiple factory resets, network reset etc. Nothing works.
31-10-2023 10:05 PM
Same for my TV since doing a smart hub reset.
03-03-2024 07:39 PM
Exactly what is happening with me. QN65QN9OAAFXZA Can't reinstall Prime or Apple after smart hub reset... Multiple chats with Samsung. Two factory reset of TV tried all the things! Netflix, Hulu, YouTube, etc work just fine.... We need a fix!!!!!!!
15-07-2024 11:31 AM
Having the same issue with my TV. Called Samsung help and they tried to say it was a signal issue. I've reset my TV several times and Prime and Apple still not working or downloading. Very frustrating. If it's a known issue surely someone can assist.
