Go to solution Solved
UE55NU6035 can't connect wireless screen from my pc after updating it to win11
(Topic created on: 07-01-2022 04:38 PM)
Joo1
Used to mirror my pc to the tv with wireless screen option but after i updated the computer to win11 it can't connect.
Hoping samsung will fix this with a future update for my tvmodel UE55NU6035.
Or does anyone have any nice solution to my problem?
#UE55NU603
#windows11
#screenmirroring
Pugs1957
SuperStar
Sounds more like a Windows problem as that's the only thing that's changed.
4 REPLIES 4
Pugs1957
SuperStar
Joo1
Yes probably but i wanted to adress it so if it's a shared problem with other users it might be fixed :smiling-face:
Also, i updated windows and now i can connect with the video to the tv....but not the audio.
I sent in feedback to microsoft about this so hopefully they can fix that.
Pugs1957
SuperStar
If you are streaming media from the PC, try installing a codec pack as these may be missing.
Joo1
Got all latest updates from windows. Now it works 😄
