10-04-2022 09:50 PM in
TVOwn this smart TV for 10 years. Since a few weeks ago, it turs off on its own after a few seconds.
Tried to connect it directly to the mains, a master reset bot no chance.
According to the Samsung service the problem is in the main board but they di not have spares. I do not want to throw it away and would like to repair it.
Does anybody know what are the components of the main pcb which must be replaced? Unfortunately I do not have the electronic diagram but have the tools and knowledge to do the repair.
Many thanks in advance for the help
11-04-2022 08:50 PM in
TVHI @Vicenc I imagine the situation is as the Samsung service centre described. I take it you have the latest firmware,2015was the last time it was updated https://www.samsung.com/uk/support/model/UE40D6530WKXXU/ If there is no light flashing when it switches off definitely a fault. Whilst may not much difference could try disconnecting for an extended period but I suspect the main board is the issue.
Personally think it will be difficult to source the parts and after a decade Smart Tv's will tend to run into problems.
One Ui 4.0,Android 12 Official Version.
12-05-2022 06:48 PM in
TVHi James
Many thanks for your reply. You were absolutely right. The culprit for the malfunction is the main board.
I have been trying to find either a brad new or a second hand main board to repair the TV which, by the way, is in excellent condition but so far no chance to find the BN41-01587E main board.
Any advice would be welcome if any other member of the community knows were I could source this main board.
Someone mentioned that a main board for any set of the 6500 series would do the job but unfortunately I do not have access to those part numbers.
Anyway, many thanks for your reply.
