05-10-2023 03:52 AM
My mom's TV was working fine yesterday but, I turned it on today and it had a very dimmed screen,like it seemed like the TV was still turned off with the lights on type dim. I tried everything,unplugging and replugging,factory resseting the TV, trying to hard reset the TV, turning off settings that messed with the brightness in anyway, etc. Anyone here know a solution to this problem?
05-10-2023 07:23 AM
Check the display and eco settings, the latter does have an auto dim function, according to ambient light conditions.
2 Decades Samsung Ownership, If my response helps leave a Like and Accept as a Solution
DAILY: ZFold6, Watch Ultra, Fit3, CL Ace 2, BT-W6, 20,000 Power bank, Smart Tags
FAMILY: ZFlip5, ZFlip6, Watch6 Classic, Tab S8 Ultra, Tab S7 Plus, Buds Pro2, Buds3 Pro
OFFICE: Book2 Pro i7, M70A 32”, Logitech K700, MX Ego, M720 Triathlon, Pop, Jabra Evolve2
AV/GAMING: QN95A 50” TV, Q900A, SW900s, 8 Series TV, LG OLED, M70A 43”, Dell Inspiron G5
APPLIANCES: Jet 75 Vacuum, MC32 Oven, American Fridge, 8 Series TV, LG OLED
SPARES: ZFlip4, ZFlip3, Buds1 Pro, Buds2 Pro, Book2 Pro i5, Level Speaker
MAINTAIN: iPhone 14, iPad Air4, iPad Mini4, iPad Pro1 12.9, Watch6
05-10-2023 12:19 PM
The TV doesn't come with any eco settings and I believe I did turn off anything that had to do with ambient lighting as well and it still stays dark.
05-10-2023 02:00 PM
I have been having the same issue as well I have turned off all of the eco settings but the TV is still going very dim at random points
05-10-2023 04:27 PM
@Jerick: Please can you confirm the model number of the TV you're having issues with? This can be found on the sticker on the back of the device, or in Settings > Support > About This TV.
If you have any external devices connected to the TV, then please be aware that some devices can enter an idle/power saving state when you don't interact with them for a certain time, and this can cause the screen to dim. With this in mind, please try interacting with the TV, and any connected devices, to see if this helps.
05-10-2023 08:18 PM
My mom has a model UN43TU7000FXZA,this is the model We're having problems with.
04-01-2024 04:37 PM
This happened to me too. Did you ever get a fix for it?
04-01-2024 08:42 PM
This just started happening with my new Frame TV as well, and I've turned off all the eco/auto-dimming settings, and it is still occurring.
04-01-2024 08:53 PM
Mine is so dim I can't even figure out how to get to the menu. I know it's on because I can hear it but other than that maybe once in awhile I can see a shadow or two if it's a bright scene. It's unuseable. I guess Ill just get a different brand from now on, this is frustrating.
30-03-2024 05:20 AM
Samsung - THIS IS A PROBLEM. BRIGHTNESS does not change when you slide the Brightness from 0 to 5. This is a problem with SO MANY OF OUR TVs.
We should all file action with the state attorney generals and make sure that everyone knows that SAMSUNG TVs are garbage. TWO of my frames have this problem.
THIS IS HORRIBLE.
FIX THE PROBLEM
