TV's that have 1gigabit ethernet port?
(Topic created on: 08-04-2024 08:19 PM)
LewisJMac
Hi everyone,
Looking to find out which TV's, specifically Samsung if possible, have a 1 gigabit ethernet port built in? I'm trying to stream IPTV and other services but the constantly buffer. My Internet speeds are around 350mbps but my TV only states 100 with ethernet cable plugged in, this I believe is because of the maxed 1/100mpbs port.
So technically, you would think, not using the ethernet cable would be better however it is not.
So, what tvs have thi? Many thanks in advance.
7 REPLIES 7
UNKNOWNUSERNAME
Samsung Members Star ★
what type of IPTV are you trying to stream? I think 100mbps is the limit over ethenet.
MPNI2025
LewisJMac
A well known pirate service with lots of channels. But YouTube also struggled at max settings
UNKNOWNUSERNAME
I personally have never had issues when my TVs are not hardwired. Netflix runs fine, along with prime video etc. Maybe try wireless instead ?
MPNI2025
LewisJMac
Wireless also buffers for the IPTV. Netflix and prime is fine. I guess it's down to the constant live feed transmission
UNKNOWNUSERNAME
i highly recommend a new gen chromecast for IPTV, works perfect.
MPNI2025
Gurky
Helping Hand
Sounds like very very poor compression from IPTV, you can stream 8K YouTube with 50mb, and a very blu ray rips don't hit close to 100. I've never seen the obsession with more than 100mb nothing uses it.
cavalloacquatico
I don't know of any, but pinkberry should fix your problems.
