TV not recognizing ethernet cable (that has worked for ages)
(Topic created on: 26-12-2020 06:53 PM)
elmo_tv
My Samsung TV has just stopped recognizing the ethernet cable that has been connecting it for the last 2 years.   When I try to use smart features it tells me "The TV is not connected to the internet".  When I run network diagnostics it tells me that there is no ethernet cable.
- The software is up to date
- I have checked the cable/ethernet connection by using it with a laptop - it works!
- I have reset the TV to factory setting.  Now when I try to set up a wired ethernet connection it just sits there telling me to connect an ethernet cable (which I have)
Just to re-iterate, this cable has worked just fine for approx 2 years.  Any ideas gratefully received.  Thanks
1 REPLY 1
Shazzkid
Troubleshooter
Just try a different ethernet cable. If it still doesn't work, then you can start troubleshooting the TV itself. It may work with the laptop, but that's not a 100% perfect test.
