11-03-2022 06:25 PM
Hi
I have a samsung soundbar HK-650w that was connected to my Samsung TV UE65KS8000 via bluetooth. The TV no longer detects the soundbar and fails to connect on Bluetooth. I've updated the firmware on the soundbar and also the TV still no luck. I've removed the soundbar from the TVs bluetooth list and when I've tried to pair it, it cannot find the soundbar at all. Individually both soundbar connects to my Samsung mobile (Note 10+ 5g) so bluetooth is working on both on the soundbar but pairing TV/mobile fail.
TV and soundbar on optical work fine but the stupid timeout on the soundbar means I'm having to switch it on everytime I pause it as it times out after just a few mins, even after the firmware update
Is this a repair job or is there anything i can try with the TV to get the BT working?
Thanks
11-03-2022 06:47 PM - last edited 11-03-2022 06:47 PM
11-03-2022 09:03 PM - last edited 11-03-2022 09:06 PM
Hi @Members_0MNdoB9 Is the model HW-k650? Anyway could try to reset by pressing and holding the fast forward button or play/pause for 5 seconds. other ideas other than those provided in other link would be to reboot both Sound Bar and Tv and factory resetting Tv.
If it is HW-650 some troubleshooting here https://downloadcenter.samsung.com/content/UM/201703/20170320114806093/HW-K650_K651_ZA_170111.pdf
15-03-2022 06:39 PM
Hi thanks for your replies and I've looked at the info you indicated. I previously had the soundbar working fine. I've tried the factory reset of both TV and soundbar. After factory reset, I can get the Soundbar to work fine with my mobile but the TV doesn't recognise it. Similarly my TV and phone won't connect via bluetooth (they used to). So the common denominator is the TV. Any other options I could try?
16-03-2022 01:05 AM
HI @Members_0MNdoB9 A few suggestions, firstly you could try a Cold Reboot by unplugging Tv from mains and holding down the Power Button for 30 seconds and then connecting again. This method can restore default Boot options.
You could also ensure BT Audio is enabled in the Service Menu. However only do so if confident and ensure you do not change anything in error.Turn Tv off and with a standard Remote enter the following sequence of keys Mute,1,8,2,Power. Alternative option is Info,settings.Mute,power. if successfully enter service Menu check option-Engineering option-BT Audio. see some information here https://en.alfanotv.com/smart-home/how-to-access-samsung-smart-tv-service-menu/
However possibility there is a hardware issue.
28-04-2025 04:03 AM
The cold start worked immediately. 1st I unplugged the tv, held power button while off, then the soundbar and subwoofer for 30 seconds. I then plugged in the soundbar n subwoofer then switched it to d:in then plugged tv back in and turned on and immediately recognized soundbar system. I also before had them setup on smart things way prior.
28-04-2025 04:10 AM
I 1st did the method you suggested with the mute, 1, 8,2, power, didn't work then I unplugged tv, held power button down for a few, then unplugged soundbar n subwoofer. Then plugged soundbar system back in put it on d:in plugged tv back in it started right up and instantly recognized soundbar system!. Appreciate the help
28-04-2025 08:33 AM
