06-04-2024 08:13 PM
hello made big mistake changing LED to PDP in hidden menu after i exit turned the tv on but no pic or sound i tried to back to change it again but the tv wont let me MENU.!.8.2 and power
any idea will be great
06-04-2024 09:18 PM
Hi @Astrofannumberone Alternatives are INFO -MENU - MUTE - POWER and MUTE - 119-Power. However if to no avail unplug at the mains off the TV for at least 5 minutes and see if this makes any difference. You could try a flash reset which does not require the TV Menu. Under the Samsung logo on the TV you have a small black button about 2-3cm in from the bottom edge. With the tv turned on
1. press the button at the logo for 5-10 seconds
2. Release the button
3. press the power button on the TV Remote for 5-10 seconds. Tv goes black and then restarts after a while. This is called the flash reset
However some inadvertent changes in the Secret Menu can result in critical errors.
06-04-2024 10:55 PM
Thank you for your response.i took the back cover i looked every where for button no where to be found,the only thing is touch power but not a physical buttons.i tried 119 but no help i tried too many method but no avail.now what?
thank you
