08-01-2021 06:51 PM in
I am about to set up my new 43" Q6.
I planned to insert the legs while I checked everything, and then intend to mount it on the wall. However, I have seen some issues raised about removing the legs once they are installed.
Can anyone give me some advice?
Thanks.
Solved! Go to Solution.
08-01-2021 07:54 PM in
09-01-2021 10:24 AM in
Hi Andrew
The model number is QE43Q60TAUXXU
Hope this helps
Chris
13-01-2021 01:44 PM in
Hi Shazzkid
Thanks very much for your input - great reassurance!
I have now put the legs in and taken them out again without any problems.
Thanks again for your help.
23-01-2023 05:57 PM in
They snapped in and I can't get them out
