Go to solution Solved
TV HDMI Control of Sky+ Box - How to Reset?
(Topic created on: 10-04-2023 01:48 PM)
TheCurmugeon
I have a 12 month old QE75Q80A that worked fine until I had to do a Smart Centre reset.  I'm now pretty much back to normal (after a heap of hassle), had to do a complete reset from square one.
However, I now can't get the remote to control to talk to my Sky+ box over HDMI.  The TV knows it's there but won't control it.  I've been through the settings menu and the e-manual a hundred times but can't find a way to either reset it or to start again with the box as a "new" device.
Any ideas please?
TheCurmugeon
Sorted, after getting the right info from another forum.  For the record, the procedure is:
  • Disconnect the Sky+ box from HDMI.
  • Enter Samsung Smart things and delete the Sky+ box
  • Re-connect and start again from square one.
This only works when using the solar powered smart remote, not the larger, clunky one with all the buttons.
1 REPLY 1
TheCurmugeon
