Go to solution Solved
TV Going Crazy with Messages
(Topic created on: 10-03-2024 02:23 AM)
wasatchglen
I have a QN55S90CAFXZA just bought in Nov 2023. This problem was mentioned in a 2022 post but the solution is not available on my TV. " TV is taken over by a messaging cyclone; "Microphone is turned off" all smart features may not be available , then again " microphone is turned on" all featured may not be available. It goes for 45 to 100 times then some gap and again starts." Tried several fixes but nothing working. Any ideas?
wasatchglen
Thanks for your response. We seem to have solved it by finally finding the itty bitty button at the bottom of the TV that turns off the microphone. So small - they really want to eavesdrop,
3 REPLIES 3
Stvv
If you go into Settings - TV Device Manager, is your TV storage full by any chance?
wasatchglen
Dsudan
I have exactly same issue. Tv is just a couple of weeks old. I tried turning the microphone off and and on many times. It stops giving notifications as soon as I turn the microphone off but starts again as i turn it back on.
