08-04-2021 01:26 PM
Reaching out for help, thanks for reading.
I changed my Samsung The Frame TV (2019) for this new Samsung 8k TV in 2020. I assumed the One Connect cable would be the same, and I would simply plug in the 15m cable built into the wall to hide the One Connect box at the other side of the room. I discover it is different, and I'm told on one Samsung expert call that the cable I require is VG-SOCM15 (why they change the one connect cable for each new TV version is beyond me?). Breaking all my walls again is unappetising, but worse still I cannot find this cable to buy (and cannot get any clear answer from Samsung).
Any ideas very welcome!
08-04-2021 01:32 PM
08-04-2021 01:42 PM
Thanks, yes I have tried eBay. I saw one with the correct cable number but it says it is for 2017 Q versions - I understood the VG-SOCM15 was just for 2020. Maybe worth an expensive punt though!?
