Go to solution Solved
Time shift on bu8000 50 inch
(Topic created on: 12-07-2022 09:30 PM)
MHH76
Just bought a bu8000 50 inch tv, can't record or do timeshift, Does this tv support timeshift in the first place?
2 Solutions
MHH76
I wrote the question on amazon and Samsung replied that this model does not support recoding nor timeshift
CTodhunter
Yup, I have had a chat with support... no joy.
I've suggested Samsung update the e-manual to reflect the model and the make sure the specs are listed on their web site.
Not sure why it supports HDDs attached to the TV now!? Seems a pointless feature now.
Thanks
3 REPLIES 3
CTodhunter
Hi,
just wondering if you found an answer? I've just got the same model. It will read files on the USB disk but trying timeshift gives me "Not Available"
MHH76
CTodhunter
Thanks
