21-02-2024 10:59 PM
After 6 months of torture using the Odyssey G7 which would consistently keep giving me flickering or rolling band issue when connected to my MacBook Pro 16 inch M1 Pro Laptop, I just got the Samsung Odyssey G6 now after connecting and using for almost a few hours I have not found any issues with lag or flicker or rolling band but what I can not seem to find is how to shift my refresh rate from 60 to 120 or 240.
When I switch the monitor to Game Mode: ON then I get the option for 120Hz but with Game Mode: OFF it doesn't go beyond 60Hz.
I am using an ANKER HDMI cable with a refresh rate of 240 as mentioned in its packaging.
Now my question to the community is that is this caused due to the cable I use or color profile settings or something else?
22-02-2024 10:29 AM - last edited 22-02-2024 10:33 AM
25-03-2024 02:54 AM
hey i have the g65b 27 in and im using a displayport cable(i tried the one that came in the box and my own) and i can only set the monitor to 60hz with the refresh rate from the monitors settings set to extreme and game mode on with hdr.please help?
01-04-2024 07:11 AM
i had a similar issue i bought the same montior, and then i plugged in my hdmi which was ugreen, and then it would only run 120 hz and then i plugged in a usbc to display port, and the montior would not even pick up the signal, and now i have just ordered a hdmi to usbc that is capable of doing 2k 240hz, and i only did htis because in the monitors user guide it reccomended if you do not have a display port use a hdmi to display port so that made me assume that that would allow me to run the full refresh rate
03-04-2024 11:22 AM
hi, the odyssey g7 comes with HDMI 2.0....HDMI 2.0 only supports a maximum 144 hz refresh rate on 2 k resolution and 60 hz at 4k resolution. if you want to use 240 hz you need a display port 1.4 cable
02-05-2024 08:03 PM
i have a g6 32" and i see everything a lil pixeled and every setting i veeify it says that it goes only 120hz and i bought the 240hz option.............
yesterday
I have the same problem.
Have you found a solution to the problem?
