The Frame TV 2019 doesn't work
(Topic created on: 26-09-2019 07:44 AM)
Massig
Pioneer
The main point of the Frame TV is that it should turn on when you walk in the room and then turn off when you are not there.
So far this very simple function does not work reliably. Mostly it does not turn on... At times it does not turn off. Tried all trouble shooting tips... Latest firmware... Reset... Nothing. No word from Samsung either.
7 REPLIES 7
ChrisM
SuperStar
Hi @Massig
Could we take the full model code and software version of the TV please? Go to Home > Settings > Support > About This TV.
Massig
Pioneer
Model is QE49LS03RAU
Firmware...
Upgrade File(USB type) ver 1318.0 (MULTI LANGUAGE): All Windows2019-08-29
This is the firmware I was asked to download by Samsung.
Interesting that is version 1318...on 29/08...as actually originally I had v. 1315 which was from 29/08...so the number changed but not date. The US samsung site is still at 1315... Weird.
ChrisM
SuperStar
So have you updated the TV to the new software and are you still having issues?
Massig
Pioneer
Hi, yes. I am on v 1318...and the issue still happens.
Tebds to not turn on after a few hours it has not woken up.
The eco setting on turning off after x hours is off.
But for example in the morning or after the day out... Ie a few hours of the TV not turning itself on in frame mode, it does not work. Almost as it went in deep sleep... Or I have a concern on an intermittent issue in the sensor.
Massig
Pioneer
Have been away 2 days and when I got back it did not turn on.... Light on... Waved and moved in front of it... Totally black
Wippo76
Navigator
For me turning off nightmode in the art mode settings
Helped me to get the sensor working
Like it should
Hope this helps for you too
Eumeleins
Pioneer
Well known Samsung Frame problem 😞
