The Frame LS03B 2023 Wifi Issue to reconnect when switched on QE85LS03BGUXXU
(Topic created on: 08-08-2023 06:58 PM)
FrameTVUser1
QE85LS03BGUXXU  Frame TV 2023 randomly do not connect to WIFI when switched on roughly once every 3 - 4 time switched on the TV
it takes me to Wireless connection Screen, when I click Re-try button, most of the time it gets connected to Wifi
some time I need to switch off and Switch it on back, then try the re-try option it works
in the above scenario when my re-try option is not working I don't see any wifi routers available even my neighbors
1 REPLY 1
FrameTVUser1
Recently connected to wired network and disabled the wifi connection, now no issues with Internet connection
not sure if it's the WIFI of TV having issue or the Internet service provide causing issues
