The Frame 43" 2021 and patch ver 1805.4
(Topic created on: 23-09-2021 08:43 PM)
Mescalamba
Pioneer
So, here we go.
I patched it.
And it does nothing at all.
Random blink issue when connecting to new source (PC)? Still there.
Not working HDMI 2.1? Still there.
Honestly couldnt find what it actually changed. What I can say is that it didnt fix any problem for me. So from March till now, no fix for rather crucial problem of new Samsung TVs? That should get some "completely incompetent manufacturer" award. Or class action lawsuit and mass RMA.
3 REPLIES 3
Csiddnoi
hi!
as far as I know The Frame 2021 43 inch version does not have HDMI 2.1. I think HDMI 2.1 can only be found on 50 and 55 inch
I was having issues with HDMI cable so I switched to another one and it fixed the connectivity issue
Mescalamba
Pioneer
HDMI is part of One box and as such all Frames have HDMI 2.1 on port number 4 and are marketed as such. 43" and 50" have limit of 60hz refresh rate at 4k.
Its not hard to prove since 4th slot simply doesnt work with input signal plus and results in black screen, same for any size of TV and nobody solved it yet.
Csiddnoi
Note: The 43" and 50" models have a 60Hz refresh rate and don't support VRR.
