The Frame 32” 2020 tilting/twisting Wall Mount Solution
(Topic created on: 13-07-2020 09:24 AM)
Chris_mac
I want to get my 32" Frame on the wall but require it to be angled to view so the flat mount the comes with it isn't suitable.
Has anyone found a way of mounting to an adjustable wall mount?
I have spoken to Samsung live chat and they've just tons me it's not VESA mountable but offered no other solution.
99 REPLIES 99
EggyMan
that 8 mm extra won't be a problem. The pivoting mount has a certain range of adjustment, and it will easily handle 8 mm wider.
EggyMan
About $45 Canadian.
Pretty straightforward to install if you are comfortable installing wall anchors. The pivoting stand comes with some wall anchors and bolts.
Wall anchors are fairly heavy duty, but it will depend on your wall type whether you use them, or get something else from the hardware store. You have to feel confident drilling and setting sturdy wall anchors into the wall.
The assortment of machine screws to connect to the tv are all too large ( M6 & M8). Because the TV is so small, you need M4 machine screws (get the same length as the M6 ones provided with the stand.)
Ignore the screws provided with the TV, they only work with Samsung's weird tv mount.
theframe1
hi, I just bought the QE32LS03TCU model. Could you please explain to me in detail how you mounted the support to attach the smart tv to the wall? Thanks in advance.
theframe1
Anthony2577
Amazon Brand - Eono TV Bracket Wall Mount Swivel and Tilt for Most 42-70 inch TV, Fits VESA 200x100-600x400mm Max. Weight up to 45.5KG, Dual Arms Full Motion TV Wall
This one should do the trick based on specs
Mount with Cable Management PL2617 https://www.amazon.co.uk/dp/B082D8BX6G/ref=cm_sw_r_cp_api_glt_fabc_T4GVEBEZE0DXV4X5VP91?_encoding=UT...
rlbackbeat
Hi all,
After reading through the advice on this forum, I found a mount that works perfectly for US shoppers, the Echogear EGLF3. The brackets fit the Samsung 32 perfectly with nothing sticking out beyond the edge of the tv on the top or bottom. I imagine that many of the other Echogear mounts with similar characteristics will work as well, but I can say for sure that this one does as I've installed it successfully just last week.
Hope this helps!
https://www.echogear.com/tv-mounts/full-motion-tv-wall-mount-for-43-82-flat-screen-tvs-eglf3/
Annabellecc
I found this page last night and was sure I could find a better solution. This method works, however drilling into your TV makes your warranty void. I discovered if you use a mount designed for a larger TV (65” +) is perfect (Mine is designed for 40-65” TVs and is a perfect fit, however it is a tight fit so I would recommend sizing up). I will link the mount, it is pretty pricey but I’m sure there are cheaper options available.
https://www.thegoodguys.com.au/vogels-full-motion-tv-wall-bracket-large-40-65-inches-wall3345b
Hope this helps!
Karmel82
Hi to all, recently I have bought this support
 https://www.amazon.it/gp/product/B08GKWLN8L/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 .
I have cut the vertical bar beacuse was longer than TV about 8 mm and used screws M4 L16. Another thing was to adjust the holes to fix the low horizontal bar to the vertical one. I hope this info can help some others. An alterntive product is
 https://www.amazon.it/Meliconi-Slimstyle-Supporto-Orientabile-Protettivi/dp/B07TXLDCDP/ref=sr_1_1?cr...
Hellzers
Hi @Nagnag79 , I bought the same products you suggested, however the VESA converter manliness product is very heavy and only seems to have 2 holes which align with screw positions on the Samsung frame. Did you find that was enough to secure such a heavy panel? If you have any photos you could share that would be great! Thanks in advance
Hellzers
*Monlines not 'manliness'🙈 Flippin auto correct at its best!
