Go to solution Solved
The Device is Connected:
(Topic created on: 15-01-2024 06:55 AM)
Hjm68
I have renamed my network, I have changed my WiFi password, I have even used a wired connection to my tv and went wireless.
I have reset my tv (three times) - not doing that again
I have even unplugged my Ethernet cord from the tv after changing my network password and name, reset the tv and I still get the same annoying message:
The Device is Connected:  Snoo
What aren’t you telling us, Samsung?
I have seen other similar posts on your comm board and not one has a solution.
what aren’t you telling us????
Lisax4156
I have this issue as well! I've narrowed it down to the remote as it only shows up when I press a button.  It says it was connecting my Galaxy Watch6..which is mine. And I never paired it to my TV. The  watch doesn't show up under Bluetooth devices either..just my Xbox controller which I deleted.
My husband figured it out!!!!
Just reset/re-pair the remote to the TV!!
That worked for me! I have the 65" Neo TV!
8 REPLIES 8
Hjm68
Please reply with how we can go into the menu of the tv to find this connected device and stop it from connecting. I’ve already tried via Settings -> External Device Manager -> Device Connect Manager -> Device List
That doesn’t appear.
AndrewL
@Hjm68: This is certainly a strange one. At this stage, please confirm the model number of your TV, located on the sticker on the back of the device, or in Settings > Support > About This TV, and I will look into this further for you.
Hjm68
I already called Samsung and so far he issue has been solved as I allowed a tech I remote control into my set.
Thank you replying to my message.
Hjm68
Model Number: QN55Q7DAAFXZA
Tell me what you come up with.
There should be a way to see that it really is connected and to stop it from doing so.
Hjm68
As I figured. You guys ask for the model number and ——- silence.
Amateur service as expected.
Anyway, I did my own troubleshooting and determined what makes the ‘Device Connected”’ message appear.
It’s the REMOTE CONTROL.  Now, it didn’t do this when I first got the tv. It started much later - about a year later.
I can turn on the tv via Smart Things (my cell phone) and navigate the Home panel via my smart phone.
however, as soon as I use the remote, that blue framed message appears - saying the Device name is:  Snoo.
Clever spying I must say.
so, I know what must take place now to resolve this issue.
Attached is the picture of the remote:
Lisax4156
JWahid
Hey Dear,
I just came across the same issue, which was fixed by resetting my TV remote. To reset your TV Remote, you need to press and hold the RETURN and PLAY/PAUSE button for 5 Seconds.
PS: I have the same remote you shared in your reply.
Hoy23
It works!!! Thank you and your husband ❤️
