T4300 32 inch tv no thread for screws to mount to wall HELP what size screws would assist
(Topic created on: 30-12-2022 08:06 PM)
Members_s5oQ6g1
I have purchased a wall mount for the 32 inch TV but non of the screws provided fit. It is like they are too small and there is nothing to screw them onto to mount to the wall. Has anyone else experienced this if so can you please tell me what size screws will fit? Many thanks
5 REPLIES 5
T4300 no wall mount
I have the same issue. Did you find an answer?
jasto
for 32" T4300, the wall mount screw is 26-28mm M4 screw type. It explains this in the quick start guide that came with the TV I am told also
jon99999
I have this issue too. No thread for the bolts
jasto
I did buy the screws that were recommended from Samsung and they don’t fit at all. I have to say Samsung are a big Company but their after sales support it useless.
jon99999
The M4 bolts didn't fit? Balls, I've just ordered some
