22-12-2021 11:30 PM
23-12-2021 08:26 AM - last edited 23-12-2021 08:29 AM
23-12-2021 09:47 AM - last edited 23-12-2021 09:48 AM
23-12-2021 05:12 PM - last edited 23-12-2021 11:01 PM
@MDLH You could try disconnecting the aerial and Whilst no channels will be found can reset the system and then do it with aerial connected. otherwise see if Factory Reset makes a difference. However Freeview HD is being phased out in the latest models, likely due to the expansion of Freeview Play and other apps. Some customers also use Satellite and Cable providers, some Sky content is also available via the Now Tv app. however Freeview Play is not currently directly supported on Samsung Tv's., Samsung though do support the BBC/ITV/ channel 4 and 5 On Demand services. It could be that you would need a separate device for some of the Freeview channels.
Some information here: https://www.freeview.co.uk/corporate/news/freeview-announces-it-will-phase-out-freeview-hd-brand https://www.aerialforce.co.uk/how-to-set-up-freeview-on-your-samsung-smart-tv/ https://www.trustedreviews.com/opinion/freeview-play
23-12-2021 06:21 PM
