Some Judder Issues With my RU7400 55inch
(Topic created on: 11-12-2019 05:42 AM)
yuval_hal
Hello,
I will try to explain my current problem described as possible.
This is my TV details:
RU7400 55inch
Firmware version:1335
I also have yamhaa reciever RXV-485 that supports 4k connected through "Hdmi out" port to my HDMI Arc Port on my samsung TV.
I have some judder issues with my tv when it comes to the computer and my cable sat box that are connected through my reciever on HDMI 1&2.
I tried to play with the "Auto Motion" setting:
Auto or 1-10 in the judder reduction and nothing seems to solve the problem. when i turned it "off", it seems to help a little but not completely.
The other intresting thing is, that when I run for example "Netflix" or "YouTube" straight from my Samsung TV apps I'm not suffering from any Judder issues at all!!!!
Can you please give me some directions what do I need to check in this setup? where's the problem resides or related to? and what can I do to solve this annoying issue?
Thank You,
Yuval Halfon
1 REPLY 1
thedeadmandead
I have the same issue with my 65 inch TV.  I set the judder to 5 which seems to help versus 0 or Auto. Could be the app itself causing the problem since I notice the Roku does a better job versus the built in TV apps.
Firmware is 1355 but they probably need update to fix issues like this.  I noticed my YoutubeTv does not save last seen and sometimes when I use it the volume disappears.
Good luck
