smart tv
(Topic created on: 16-01-2019 04:21 PM)
tam7
Hi,im having trouble connecting my smart tv to the internet.have tried reconncting,but it says,not recognising internet,.Any help would be good,because tried ringing samsung,no anser,and cant chat to them,because it says connection not safe.
22 REPLIES 22
CarlH
Maestro
Hi @tam7. Can you tell me the full model number of your TV?
CarlH
Maestro
Just seen your other post, @tam7. I've deleted it so we can focus on this one. Can you check the software version? Press Menu/ Settings on your remote and go to Support > Software Update.
tam7
ok ill try this now,thanks
tam7
hi,it says this function not available
CarlH
Maestro
How far can you make it through the settings before that message appears, @tam7
tam7
software update is the only 1 no lit up
tam7
software update is the only 1,not lit up
CarlH
Maestro
Thanks , @tam7. Are you able to check your connection with an ethernet cable?
tam7
my model number is ue55es7000
